Forum: Old versions
Topic: VDJ Crashed?? Hissing/Static Sound
Last night I was playing music/videos for almost 4 hours without any problem. On my second to last song of the night, in the middle of the song, it just cut to very loud static. I tried to start the song in the other deck, but there was static on that channel as well. I was able to talk for enough time to reboot VDJ, but it was very embarassing.
Any ideas?
geposted Sun 27 May 07 @ 8:53 pm
I have that same problem any answers to why this happens?
try this on performances choose "autolatency"
untick overclock and safemode
It never happened to me. It would be good that everyone that has this issue write down their specs in detail, that way we could pinpoint were the problem is.
My machine is:
Gericom Hummer 2.8Ghz 128k cache
1Gb ram
80Gb HDD
Hercules MK2
External Mixer
No problems at all.
i am gettin the same problem and its not fun at all i have had it for a while...... NEED HELP BAD..... I GOT A TOSHIBA SATILIGHT 2.8Ghz 128k cache 1Gb ram 80Gb HDD Hercules MK2 External Mixer
and an External hard drive 180Gb for music their is no music on my lap top just softwere.........
Try not to use external hdd to see if it is that.
I am too getting a huge noize after a while, maybe after 4-5 hours. I use the demo version I downloaded last week, wich is 4.2r1 I think. I don't know if it is the same thing as you guys, but it's the same sound as if I tune my car FM radio between two stations and crank the volume up. SSSSSSSSSSSSHHHHHHHHHHHHHHHHHHHHH on both main decks channels, 1-2 and 3-4. No more music, just noize. Channels 5-6 assigned to samplings are ok, and I can still play samplings when this noize occurs on the main decks, but the main decks are unusable. They still work, but no music, just noize. I need to restart VDJ to fix this for the next 4-5 hours. This is also occuring even if VDJ is idling, no songs loaded in the decks.
I would like to find the source of this before my demo expires (13 days left...) because I *Really* like this software and want to buy it, but I do not like this noize.. ;-)
Here is my hardware setup:
Asus motherboard
Intel P4 3.0 GHz
2 GB RAM
2X 320GB HDD's
Sapphire X1050 PCI-X Video card
M-Audio Delta 1010 sound card (Driver 5.10.00.5057v3)
Windows XP PRO SP2
This computer is NOT connected to the internet, but has all the updates done to it. I also tried every possible performance setting combinations and both ASIO and normal sound card setups, I always get this noize after 4-5 hours.
Is it a conflict between VDJ and my sound card ? When this noize occurs, I can still use another software that uses the same outputs and hear my music under VDJs noize on the same sound card outputs (1-2 and 3-4), so it tells me that it is not my sound card and/or drivers.
Thanks everyone for your help.
Nick
this issue was declared as solved in 4.3
unfortunately the latest demo
is only 4.2
some steps you can take are
to go to the performance
set it to fastest
untick safemode and overclock
God that's a fast reply !
skyfxl, I already tried that in my demo version but still experiencing that same issue.
Do you know if there will be a demo of the 4.3 version ?
@ lajolladjs
@ djgalaxyproductions
@ dj_d_crayz
What version are you guys using ?
Nick
expecting a 4.3 demo very shortly
Will I be able to try the 4.3 demo even if my 4.2 has expired ?
when it is released make a support ticket the team will help you with that as you are serious about buying the software
Thanks.
I am very curious to know what versions lajolladjs, djgalaxyproductions and dj_d_crayz are using.
djgalaxyproductions : 3.4 (home edition)
Dj _ d_ crayz : 3.4 (home edition)
3.4 is very very old
about a year and a half
and comes free with consoles
not sure about lajolladjs
nick3478411
i am useing 4.2r1 it was an up grade my buddy bought it and sold it to me he lost his key so he found me a new one but i cant register it but any ways i got my prob fixed it doesent matter where your preformance tab is but you got to set latensey to auto and un tic safe mode and overclock but now my other prob is tcv sounds a little digital any ideas
your using an ilegal outdated and unfixed version
it is forbidden to sell your software,
buy a proper version if you want good results and
if you expect to recive support
i hope to see you as a pro user soon.
