Forum: Old versions
Topic: when opening virtualdj
when i open virtual dj an error message comes up saying
''error in the sound driver of directX''
it still lets you browse through records but when you press play to start a record nothing happens.
any help muchly appreciated.
geposted Sun 27 May 07 @ 9:08 pm
You need to reload, or up date, your directx drivers. If that doesnt work you are going to need to delete and reload VDJ.
thanks.
how come i've been using virtual dj for a while and then suddenly that happens? is it anything to do with me trying to use a usb sound card?
iv just updated directx to directx10.
same problem occurs.
after the error message comes up, you can still drag records onto the decks, and press play but no sound and the bars at the top don't move. yet when you go to close the program it still says 'the music is still playing are you sure you want to exit?'
thanks.
ukfcn wrote :
thanks.
Define a while... The trial version is only good for 30 days. If you are using a cracked version good luck, because not only will there be bigger and tougher problems but, no one here is going to help you. But in answer to your question, no using a USB soundcard will not cause the problem you are experiening...
direct x error means strangly enough you have the wrong song config
please check it and close vdj and try again
Actually trial only for 20 days:)both VDJ and CUE
go into config' and check your sound setup is on right settings...worth a try..
Tayla is right, your sound config is changed, so check it out and choose the sound card you wanna use.
That's usually the case because a lot of the time I open up my Shuttle with no connected sound card or sound out jacks, so the program sees that as an error although the program will function normally, which means that the sound setup is incorrect, that's all.
