Forum: Old versions
Topic: audigy 2 and mk2
hey i have a hercules mk2 and a soundcard audigy 2, is it possible to make use of my audigy 2 with the mk2 so that i can achieve low latency's when scratching, or is this not possible, its just i think my audigy 2 will be better than using the mk2.
so basically can i use mk2 but make the sound come from my audigy 2 instead?
thanks
geposted Sun 27 May 07 @ 9:40 pm
Yes, you can use MK2 only as controller and Audigy as a sound card. You can setup MK2 for low latency using www.asio4all.com drivers.
yeah ive got those asio4 drivers, but i was wondering whether my pci audigy 2 would perform better than the mk2 in terms of latency?
anyone know if it would?
thanks
