Forum: Wishes and new features
Topic: Loading "patches" in the sampler
the sampler is cool, but could easily be much more powerful. One thing that could really speed up the way one works with the sampler would be if one could load up each sampler channel in one go. Loading "patches", like for instance with music software where you can load a "patch" (multiple sound samples) ofsounds into say, the drum-machine, instead of loding each and every channel one at the time.
Should be easy enough to incorporate right? It would save us a lot of fiddling, and allow for more varied sample-use.
geposted Sun 27 May 07 @ 9:51 pm
k_onePRO InfinityMember since 2006
true, loading a set of 12 samples at a time would be great..saves a lot of work and time.
And as you said, it shouldn't be to hard to implement...
geposted Mon 28 May 07 @ 2:31 am
djsherzPRO InfinityMember since 2006
geposted Fri 01 Jun 07 @ 2:02 pm
