Forum: Old versions
Topic: Converting Kok files into CD+G files
dydy1PRO InfinityMember since 2006
Does anybody know how to Convert Kok(karafun) files into CD+G files?
Is Kok files compatible with Virtual DJ?
geposted Mon 28 May 07 @ 2:44 am
no and no... this is why you should never convert to a proprietary format, or at least if you do, keep a backup of the originals....
unless the maker of the kok files creates a converter program, you're stuck sucking kok.
sorry, I had to... :)
geposted Tue 29 May 07 @ 11:59 pm
