Forum: Old versions
Topic: Split mode problem
Hello!
After installing an update for MK2, the Headphone Split-mode dos not function properly.
If the cross fader is in position to the left (deck A) it plays as it should. But when I slide it over to the right (deck B) the music from deck A fades out.
Can anybody help me with this problem?
Regards
Mads
geposted Mon 28 May 07 @ 11:49 am
Which update you installed? I still use 2006 one and it is working ok.
It was the 2007 update.
When I realized it didn’t work I reinstalled the 3.2.0 2006 driver, but the problem remained.
Did you updated firmware of MK2?
No, I only updated the Driver.
The Support/driver link of Hercules.com doesn’t work right now, but I will try it as soon as I can. Thank you!
do system restore n then reinstalled the 2006 driver. it will then not bothered abt the msg files. and its works. i done that a few week ago b4 i itchy installed the 2007 again.. but the funny part it work this times round but the headphone input when using with asio4all sound very distorted n the hissing, it is unbearable. And also it always beyond logic even tho i disable the midi part n stuff like that.. i thinkin will try to clean the OS n then try to reinstalled the 2006 driver.. again..( 2006 is still the best:))
