Forum: Old versions
Topic: ERROR IN VIDEO DRIVER
HEY DJAYS, I NEED SOME MAJOR HELP OR ADVICE. I AM GETTING AN ERROR WHEN TRYING TO USE VIDEO FUNCTION IN VIRTUAJ DJ.. DOES ANYONE KNOW WHAT THAT MEANS AND HOW I WILL BE ABLE TO USE THE VIDEO EFFECTS OR EVEN PLAY VIDEOS. DO I NEED SOME OTHER TOOLS FOR MY IBM LAPTOP?
geposted Mon 28 May 07 @ 9:09 pm
hi
will try to help best i can with the limited knowledge i have, anyway bog standard question everyone gets asked have you the latest drivers of directx10 i'm still running on 9 with no probs, if the answer is yes go into config settings open up video tab when opened underneath video output at the top left, left click activate, next to tv output if you just want to see vid on your pc screen it should be set at - window or if you are sending a signal out to screens select your video drivers, mines nvidia. In the options box at the bottom left click to activate 'use this plugin for audio files' i choose sonique if you have'nt already got the pluggin go to the download section and get it (not sure if you have access but worth a try), it has some good visuals when playing audio for your screens but you may want to delete some of the more naff ones hope this helps...
Tayla
whats your spec?
I'd have to ask the same questions .... what are the tech specs on your machine? Most often these types of errors occur when your video board doesn't have enough 'firepower' to handle the video processes or you just don't have enough memory. I had to replace my top-of-the-line Toshiba Satellite with a high-powered gaming laptop to get enough video firepower for everything to work normal.
NickyB
"you may want to delete some of the more naff ones hope this helps... "
Can you tell us the names of the ones you deleted from the list, Thanx????
bryantpb
i think its more upto personnel taste than me giving you a breakdown of what i deleted, set up vdj then go into sonique pluggins and play them one by one and delete the ones your not keen on i think i removed round about twenty...
Tayla
