load a .wav drum loop into a sample slot.
use sampler menu to set it as 'loop' and 'beat lock'
press play. sample shows 'jingle' not 'loop'. it does loopbut it is not beat locked to currently playing track.
seems not to work quite right, or am i doing something wrong?
thanks
matt b
thanks
matt b
geposted Mon 28 May 07 @ 9:58 pm
I think (allthough I may be wrong) that to have a sample to play as a loop you have to "record" it from one of the decks with a loop set on it. That way the sample will contain both bpm info and loop length information.
I know that this works, but there may also be another way that I'm not aware of. Hope that helps.
geposted Mon 28 May 07 @ 10:48 pm
