here are the SPec for my new laptop, this should work with vdj right? to run video
Inspiron E1705
Intel® Core™ 2 Duo T7200 (2.00GHz, 4MB L2 Cache, 667 MHz FSB), FREE Upgrade to Genuine Windows Vista™ Home Premium with 1GB of memory
Inspiron E1705
LCD Panel
17 inch Wide Screen XGA+ TFT Display with TrueLife™(glossy)
Memory
1GB Shared Dual Channel DDR2 SDRAM at 533MHz
Video Card
256MB ATI MOBILITY™ RADEON® X1400 HyperMemory
Hard Drive
Size: 120GB SATA Hard Drive (5400RPM)
Operating System
Network Card
Integrated 10/100 Network Card and Modem
Adobe Software
Adobe® Acrobat® Reader 7.0
Combo or DVD+RW Drive
8x CD/DVD burner (DVD+/-RW) with double-layer DVD+R write capability
Sound Options
Integrated Audio
Wireless Networking Cards
Dell Wireless 1390b/g (54Mbps)
Office Software (not included in Windows XP)
Microsoft Works 8.
Anti-Virus/Security Suite (Pre-installed)
No Security Subscription (Norton 30-day)
Primary Battery
53 WHr 6-cell Lithium Ion Primary Battery
Hardware Warranty
3Yr Ltd Warranty + 3Yr NBD On-Site Service(OCONUS Americas, not US)
Dial-Up Internet Access
6 Months of America Online Membership Included
Bluetooth Options
Dell Wireless 355 Bluetooth Internal (2.0 + Enhanced Data Rate)
Dell Digital Entertainment
Starter pack - Yahoo! Music, Corel Photo and Dell Games
Processor Branding
Intel Core 2 Duo Processor
Labels
Windows Vista™ Premium
Inspiron E1705
Inspiron E1705
LCD Panel
Memory
Video Card
Hard Drive
Operating System
Network Card
Adobe Software
Sound Options
Integrated Audio
Microsoft Works 8.
Primary Battery
Hardware Warranty
Bluetooth Options
Processor Branding
Labels
geposted Tue 29 May 07 @ 11:26 am
"Video Card
256MB ATI MOBILITY™ RADEON® X1400 HyperMemory"
HyperMemory(or TurboCache(Nvidia)) means the video card(or GPU) is sharing the laptop's main memory
not actually recommended for smooth video mixing
just playing might be okay, but if it comes to mixing(overlapping 2 videos) ...
it maybe will not handle it so smooth
you should look for a laptop with dedicated video memory (at least 256, i would say)
for smooth transitions
i know there some new ones out with the new 8000 series nvidia gpu, like 8400GT or 8600GT
haven't heard any detailed reviews, but i think they will do the job
maybe somebody here has some experience with those...
cheers,
matt
cheers,
matt
geposted Tue 29 May 07 @ 12:24 pm
Any dedicated memory video card from a 7600GT / X1600XT and above will do superb
geposted Tue 29 May 07 @ 12:55 pm
I have the 7400 with 128mb of video ram,
while I only do audio mixing it seems to work great for video mixing also ,
Thanks,
Thanks,
geposted Wed 30 May 07 @ 7:49 am
Ive got the Inspirion 6400 with RADEON X1400 256mb
The graphics card is actually 128mb dedicated then 128mb shared when needed. It works fine for basic video mixing if you dont have alot of other crap installed. I was getting alot of pops and crackling sounds with the laptop plugged into the power, but this was solved by tweaking the graphics manager program (catalyst)
Just make sure you run your machine for optimum performance. It should look like a windows 98 OS when youve changed all the settings and will run alot better. There are plenty of guides on here as to what changes to make just look in the blogs. Dont run any virus scanner while DJ and turn off things like wireless networking.
I do recommend 2gig ram though not 1, especially for vista. Get an external USB 2.0 drive with 7400 RPM to store your videos as well.
Hope this helps
Mike
Hope this helps
Mike
geposted Thu 31 May 07 @ 5:37 am
If you don't mine me asking, what was the cost of that machine?
geposted Thu 31 May 07 @ 6:46 am
Dell have had a big price drop for their notebooks you can get an Inspirion 6400 with:
2ghz intel core 2 t2700, 4mb cache, 2gig ram, 256mb video, 160gb hdd, 15.4" widescreen
for about $1700 US Dollars
I prefer the widescreen 15.4 than a 17 for using Virtual DJ Vmix 5.2 Skin in 1200x800 mode
geposted Thu 31 May 07 @ 7:37 am
i got the laptop for 1200 us
geposted Thu 31 May 07 @ 2:20 pm
Nice price! Hope it runs fine on 1gig ram, let us know! Cheers.
geposted Thu 31 May 07 @ 2:34 pm
