Forum: Old versions
Topic: Broadcasting problem (encoder tab)
Hi there,
Following on from that other thread on broadcasting I am having some problems.
On the screengrab on the other thread of the broadcast cofig tab it shows a file in the encoder field but I don't know what to use for my broadcast as there doesn't seem to be an obvious file to pick.
My settings are as follows (tried to paste a screengrab here but it won't let me paste it):
- master and mic in
-Hercules mk2
-Auto start
-Shoutcast mp3
-128kbs
-encoder field empty (this is where I am having the problem)
-broadcast to a radio server and all the relevant details
You help would be much appreciated.
I had originally tried to use the winamp soutcast plugin and although I managed to broadcast I didn't pick up the sound from my Hercules mk2. I had to just change from soundcard to winamp input setting and play tracks from a winamp playlist. Very annoying.
If anyone has any idea if I can get the winamp plugin to accept input from my herc that would also be great.
Thanks.
Bob
geposted Tue 29 May 07 @ 3:31 pm
Yeh I looked at that.
If you look on the screengrab on the first page of that ultimate guide you'll see the file in the encoder field:
D:\PROGRA~1\VIRTUA ......etc
This is the bit I have missing from the broadcast config screen.
Do I need a plugin for the encoder?
Thanks
Brilliant!
Thanks for the quick response.
I'll give it a bash and see what happens.
Its working like a dream
Thanks mate.
Bob
any time have fun :)
