Forum: Old versions
Topic: Hercules MK2 Console Upgrade
Does anyone know if Hercules has plans of upgrading the MK2 Console to compete with new controllers that are currently out? ie: Vestax VCI 100, Numark.
I received a survey email for the Hercules DJ Console MK2 back in March from Hercules, basically it asked for AUDIO & CONNECTIVITY SATISFACTION, COSMETIC SATISFACTION, USER-FRIENDLINESS SATISFACTION, Regarding the mini-stick, Would you be interested in a pitch "RESET" switch?, Regarding the jog-wheels, What DJ software that I knew, etc.
I assumed they will be coming out with a new console to compete but am interested as to when. I just bought the Vestax VCI 100 for its larger jog-wheels and if VDJ will not support it, I would be interested on the new Mk2. It would be great if they totally redesigned the console to use more professionally.
Thanks
geposted Tue 29 May 07 @ 8:57 pm
I don't know if when, but it is obvious that they will, so they can keep their name in the market. One thing that would be nice is making it so the jog wheels moved with the track like a turntable. It would be nice to be able to hold the jog wheel and have the track stop.
DJ Digital
If it comes out and have the same name it will be MK3. They should have a new name for it also.
Hopefully soon. So I can return the Vestax.
You should keep your Vestax a little longer, it will be supported for sure ;)
