Forum: Old versions
Topic: Anyone know how to fix a MK2??
McQ714PRO InfinityMember since 2003
My Deck 1 Treble knob is messing up my mixes.. apparently it's loose or just altogether bad. It won't calibrate with VDJ 4.3 and I've dl'd all updates of the software and drivers. Does anyone else have this problem? Having the treble jump all the way up or drop out completely in the middle of playing a song pretty much sucks and I doubt i'll be buying another product from Hercules. Sometimes i'll be looking at my control and then look up at the screen to see that my treble fader is moving up and down faster than i could move it myself. Maybe there's a ghost in my house and he wants to mix too???
geposted Wed 30 May 07 @ 1:56 am
sbangsPRO InfinityMember since 2004
how long have you had it
if its under two years
its underwarrenty
geposted Wed 30 May 07 @ 12:16 pm
It might just be a dirty connection. Like they said above, It might still be under warranty send it in, if not, just take it apart and clean the contacts with a Q-tip and some rubbing alcohol. I have had my DJ Console MK2 for about 6 months, and it is great.
geposted Wed 30 May 07 @ 1:30 pm
Definitely under two years.. can't find my original receipt at the moment.. but i'll try to clean the contacts.. Thanks!!!
geposted Thu 31 May 07 @ 5:26 am
frd1963PRO InfinityMember since 2004
Another solution might be to use the MK2 mapper to map that knob to something harmless.
geposted Sat 02 Jun 07 @ 10:05 am
