Forum: Old versions
Topic: serato...vdj...r they compatiable?
hey!
i'm a new user to the site but i have been using virtul dj for almost 2-3 years. my brother on the other hand is a big serato fan...long story short...he introduced me to serato's TCV...i later discovered that virtual dj has something similar to it when i saw this demo on youtube where a guy used virtual dj to mix videos. at the end he said the virtual dj softwear was compatiable with serto's usb interface... i was wondering if thats really true? and if it is...how can i use my copy of serato's scratchlive with virtual dj's softwear...? will it work on my laptop or do i have to use my pc..? also would i need to get virtual dj TCV or could i just use my scratch live TCV?
i would realy appreciate if someone could help me out....thanks in advance....
geposted Wed 30 May 07 @ 2:21 pm
I think you can use only Serato TCV's with limited function in VDJ.
*needle drop is not supported
*10% pitch difference
SO THEN IT IS HOOKED UP EXACTLY THE SAME WAY AS SERATO? ALL I WOULD HAVE TO DO IS INSTALL THE DRIVER FOR SERATO AND JUST OPEN UP MY VIRTUAL DJ? WILL THE TCV GET PICKED UP ON THIER OWN? OR DO I HAVE TO GO CHANGE THE SETTINGS?
THE THING IS IM CONSIDERING SWITCHING FROM SERTO TO VIRTAL DJ FOR MY SHOWS. THE ONLY DOWN SIDE I SEE IS THAT EVERYONE HAS IT HOOKED UP TO THEIR PC NOT LAPTOP!!!!!! IS THERE A WAY THAT WILL ALOW ME TO USE ALL OF THE FUNCTIONS ON MY LAPTOP?
