Topic: Any word on auto mix updates?
skell11PRO InfinityMember since 2006
Is there any word on an update that fixes the Automix glitches? I REALLY need ths to work properly and not jump and dump songs while I am doing mic work from across the room ... Please Help!!!
geposted Wed 30 May 07 @ 6:35 pm
Yes please, I have exactly the same problem, anybody knows if this is going to be fix on the next update ?
Thanks
geposted Wed 30 May 07 @ 6:54 pm
djfsPRO InfinityMember since 2007
i'm having problems with it changin cue in and cue out points. i want it just to play the whole song. the demo did it ok.
geposted Wed 06 Jun 07 @ 2:59 pm
Start Here:
http://www.virtualdj.com/forums/61288/PC_version_bugs_report/Automix.html
ALso If you just want it to play the whole song with out mixing goto the config menu/options go to force fade button=Enable.
Then below that there is a small slide bar. Place that all the way to the left or untill your desired mix point.
The slide bar is the force fade lenth controll.
Below that is the software crossfader curve. Set as Desired.
geposted Wed 06 Jun 07 @ 3:14 pm
cheers. i'll do that now.
geposted Wed 06 Jun 07 @ 3:25 pm
