plugged it in updated vdj to latest version 3.4.1 no sound through the pc speakers
am i supposed to plug and amp into the console then speaker into the amp to get sound out?
geposted Thu 31 May 07 @ 11:49 pm
correct
each line here is a dual phono cable
geposted Fri 01 Jun 07 @ 12:33 am
can any recommend any further hardware to go with the hercules mk2 console ie amp speakers etc
setups
setups
geposted Fri 01 Jun 07 @ 2:48 pm
what sort of gigs do you do ?
or are you using it for a home studio
geposted Fri 01 Jun 07 @ 3:01 pm
just starting home studio yes
i have both a desktop and laptop when i load hercules on the desktop there latest driver mess my current drivers up so win amp wont play
what is the mapper for ?
what is the timecode for?
sorry so many questrions
geposted Fri 01 Jun 07 @ 4:12 pm
no worries its good to ask :)
timecodes are special records that have a code on them
so when you stractch it does so aslo on the software
as a home user your limited to a 5 minute demo of these
the mapper adjusts the actions of the buttons in vdj pro
for a home studio you should get a small amp such as a hifi amp
and a pair of monitor speakers
however most computer speakers support phono inputs if you replace the mini jack cable to your speakers with double phono it will work
geposted Fri 01 Jun 07 @ 4:57 pm
