How do I get the Hercules MK2 to stop/start, scratch, loop, etc,...my songs in VDJ 4.3? How does it act as the external controler? Thanks in advance!
geposted Fri 01 Jun 07 @ 1:38 am
basicaly theres a button for each action
start for start
loop for loop ect
it works well learn more here
http://www.virtualdj.com/forums/59875/Hardware_Technical_Support/ultimate_guide_to_controllers.html
start for start
loop for loop ect
geposted Fri 01 Jun 07 @ 1:48 am
Correct but what exactly do I need to enable in VDJ so that if I move the jog wheel of the MK2 that the corresponding deck in VDJ responds to it?
geposted Fri 01 Jun 07 @ 2:13 am
maybe you go to config then tick and enable mk2 jog wheel as to scratch. hopes that helps.
geposted Fri 01 Jun 07 @ 9:06 am
You have to enable MK2 in Settings>Remote Control tab than you can set it up and use.
geposted Fri 01 Jun 07 @ 12:30 pm
yes the console is natively mapped in vdj ,
to the most comon usage
there is aslo a mapper available for download to adjust it more to your wishes
geposted Fri 01 Jun 07 @ 12:36 pm
i tried all the above and still nothing. all i'm trying to do is get the hercules mk2 to act as the controller for vdj 4.3. i've installed the software that comes with hercules, i've enabled hercules in the config tab of vdj...i'm just bummed that i can't get it to work. seems like this should be as easy as plugging in hercules and away i go? :(
geposted Fri 01 Jun 07 @ 4:32 pm
are you using the drivers on the disk?
they are to old grab them from here
http://www.virtualdj.com/forums/66083/Hardware_Technical_Support/Common_Device_Drivers___Updated_last_on__5_5_07.html
geposted Fri 01 Jun 07 @ 5:05 pm
to answer your question yes i am using the drivers from the disk. i clicked on the link you gave me but got "page cannot be displayed."
geposted Fri 01 Jun 07 @ 5:26 pm
odd it works here try again :)
geposted Fri 01 Jun 07 @ 5:48 pm
hmmmm not sure why but i get that same page "page connot be displayed." I tried it on my other computer and got the same. ohhh i know what it is...i'm just not meant to have this unit (hercules mk2). :) i'm goin to return it and get the Vestax VCI-100.
geposted Fri 01 Jun 07 @ 5:58 pm
ftp://ftp.hercules.com/pub/webupdate/DJMP3/2007_CMP3_1.exe
full install for driver needed for 4.3
geposted Fri 01 Jun 07 @ 6:01 pm
