Topic: BIG DMC2 Bug!!!!!
ok, I thought it was only on the mac, but using the fader buttons on the dmc crashes both mac and PC...
you touch the button, and the program just disappears... instant bye bye..
what gives?
am I the only one to find this?
anyone else? does this happen for you?
on all 4 of my computers it crashes the program every time instantly!
geposted Fri 01 Jun 07 @ 9:02 pm
this is straight out of the box with no mapper....
with the mapper, it does not crash...
any idea when someone is going to map the mac mapper?
-Steve
geposted Fri 01 Jun 07 @ 9:12 pm
DazmaxPRO InfinityMember since 2007
I have tried using the DMC2 with the bundled CUE LE software and found that the fader buttons work with no problems. Could this be a problem with the VDJ version of the software? Which version are you using?
geposted Fri 01 Jun 07 @ 11:59 pm
Mine is not experiencing that issue you reported. Seems to work just fine here.
geposted Sat 02 Jun 07 @ 6:57 am
are you using the mapper? it won't happen if you have the mapper... also, I'm not using cue LE, I'm using Virtual vinyl and cue r.13
It happens on 4 different machines...
geposted Sat 02 Jun 07 @ 4:44 pm
I have had it for 2 weeks. I just started using the mapper last night. Using Virtual DJ Pro 4.2 r12
geposted Sat 02 Jun 07 @ 4:53 pm
If I had a Mac, I could probably port my DMC-2 mapper across to it.
geposted Sat 02 Jun 07 @ 8:08 pm
sbangsPRO InfinityMember since 2004
when the mac sdk is finished
i could simply compile your code for you on my mac
geposted Sat 02 Jun 07 @ 8:23 pm
