Forum: Old versions
Topic: Denon Dn-S3500 Players & Virtual Dj ?
Hello Everybody!
Does Anybody have this Set-Up? and or does it work with these players?
geposted Sat 02 Jun 07 @ 2:25 am
it will work with these players and timecoded cds
you will need a soundcard with dual stero inputs such as the maya 44 or u46dj or virtual vinyl
and vdj pro
where can we get timecoded cds? Virtual Dj does not make them, correct?
quicktime only allows quicktime pro users to do it, and it says "save as source" instead
you must click on the link with the right mouse button and select in the menu "save target as".
I suggest to webmaster to put it a zip file, that way it won't confuse new users anymore ;)
Thank you for your help. I have the Waveterminal 192L and it only has 2 inputs W/ the option of one of the two being able to work at a time........ The question would be "Could I use one Input from my WT192L and use the Second input from my Onboard Audio card? Second Question "How do I know when I'm buying Pro- Vs. regular Virtual Dj?"
pro vdj is sold only this site or in the form of numark cue
home vdj comes with consoles such as mk2 , dmc2 , total control
