Forum: Old versions
Topic: Who have vestax vci 100
Maybe every DJ who use vestax controller should sign here to show Virtualdj that there are a lot of users with vestax controler and so they can solve the problem.
I Use MK2 and Vestax Controler
Vestax Users:
DJ Papaoke (Germany)
geposted Sat 02 Jun 07 @ 3:41 pm
yes they are aware and are working on it
I'll say one thing. The VCI-100 with fully working VDJ will be absolutely brilliant.
A
thats not the question! Please write your Name if you have the vestax controler.
Whats the point of that? Atomix team is working on full support on Vestax, that's all you need to know ;)
Well, Alf that's good news, but it's the first time it's been announced when Sky put it up above. ;-)
a
Keep your hair on ;-)
It is logical thing, if BCD 2000 had support than Vestax will have it too for sure since it is way better than Behringer.
Yeah, you're right , it's logical, and I think I should say that I am so pleased with VDJ for their continued development and the way they respond to new advances in controllers.
It will be so good to use the VCI with VDJ. A bit of patience is all that is required from those people who get worked up. After all they chose the VCI-100 knowing that VDJ wasn't supported, so should take it as a bonus if support is added later.
A
I have it. But would love to use it with VDJ.
I to Have the vestax Vci 100 .. Give the guys at VDJ a break , Everybody knows it is still the best dj software out. I will wait patiently .
