I have noticed that when I load a song in decka or b ,and when I hit p for play the song sounds already started for a brief sec and then proceeds to play normally.
I have set the cue for the very beginning and have also enabled and disabled the auto cue feature trying to sort this out.
Any tips or advice before my gig tonight?
Much appreciated!!
Much appreciated!!
geposted Sat 02 Jun 07 @ 4:25 pm
Is auto mix on? You might have a corrupt data base also...
geposted Sat 02 Jun 07 @ 4:40 pm
no, auto mix is off..all the songs are found with no trouble.When it starts you can just here a quick sound then continues like nothing happened.
geposted Sat 02 Jun 07 @ 10:01 pm
whats your system spec?
geposted Sat 02 Jun 07 @ 10:14 pm
try changing your audio settings in VDJ, it sounds like the last buffered part of the previous song is playing just before the new one is starting. changing the audio settings may stop this happening. try using ASIO or kernal mode (VDJ calls it 'low latency' or something) something simmilar but separate happens with TCV.
how it would have anything to do with a corrupted database is anyones guess............
geposted Sun 03 Jun 07 @ 1:42 am
Yeah, this happens to me too, but only when I use the keyboard shortcut for Play, cause I would be bringing a song in by scratching and then pressing play, but then it would stall for a second then play
geposted Sun 03 Jun 07 @ 3:58 am
My system is a Alienware Aurora m9700 AMD64 2.0 TURION 2 weeks old
2 Gig ram
120 gig HD using internal HD
512MB Nvidia GeForce Go 7900 GS
It has performed flawlessly before..nothing has changed in the config except for the automix fader being either turned on or off by me trying to pinpoint whats causing it.I played last night
by allowing the song to start prior then sliding the miver into it so no one noticed.
I did try auto mixing with a song list but with no fading enabled and all went well that way.
I had the latency slider set at 512 with overclock and safe checked .
2 Gig ram
geposted Sun 03 Jun 07 @ 4:08 pm
Maybe it's doing a stutter?
geposted Mon 04 Jun 07 @ 3:00 pm
