Forum: Old versions
Topic: Two ICDX Problem
I have a problem when i use two icdx's with virtual dj . when i play a video and try to cue up a song on the other deck i get a really nasty popping noise that makes the sound very distorted.
My specs are as follows .
VDJ 4.3 pro
2Numark ICDX's
Vestax VCI 100 midi controller
Athlon 2x duo 3800
ASUS M2N32 sli Deluxe Motherboard
4GB DDR2 400mhz Ram
500GB SATA2 drive
M-Audio Delta 44 audio card with breakout box
Nvidia GForce 6600 GT Oc Video Card.
geposted Tue 05 Jun 07 @ 1:46 am
You have a great pc, however I have dual HD to make it load faster.
try to do this, play the video from the internal HD, and load the song from a USB HD, or network.
tha will show if the problem has something to do with the data transfer from your HD.
