I hooked up cue to my cdn88 cd player and i got 100% signal but it is loosing controll when i spin my jog wheel back or when i cue a song when i cue a song at the location i want sometimes it dosen't start there and then i have to cue it again or when i hit the cue button it does not go back to the cue position on the cue program. the jog wheels are not acurate when i'm spining the jog wheel it sticks on the screen and then it moves again. its working but not acurate as if i was using real cd's. i'm using a maya 44 usb help me out guys i'm almost there!!
geposted Tue 05 Jun 07 @ 3:53 am
I have a CDN 95 which I believe has the same midi facility as the 88. I also have a DMC2 but would like to know how to hook up/set up the CDN 95. Any chance you could post your setup because i would like to work on this project.
Regards
DAZ
Regards
DAZ
geposted Tue 05 Jun 07 @ 5:06 am
can i get some answers??
geposted Tue 05 Jun 07 @ 4:33 pm
Difficult to try and find answers if you dont want to post the setup that your using. Not trying to rip off your work just wanted to help with your project and maby get some answers myself.
Regards
DAZ
Regards
DAZ
geposted Tue 05 Jun 07 @ 6:34 pm
