Forum: Old versions
Topic: numark cdn-88 & cue
I hooked up cue to my cdn88 cd player and i got 100% signal but it is loosing controll when i spin my jog wheel back or when i cue a song when i cue a song at the location i want sometimes it dosen't start there and then i have to cue it again or when i hit the cue button it does not go back to the cue position on the cue program. the jog wheels are not acurate when i'm spining the jog wheel it sticks on the screen and then it moves again. its working but not acurate as if i was using real cd's. i'm using a maya 44 usb help me out guys i'm almost there!!
geposted Tue 05 Jun 07 @ 2:52 pm
need some answers pls
what setting do you have for latency on performances?
and what timecode mode are you using?
auto latency and mode is set to smart
try relative mode
the same thing happens
this ting is fustrating me i tried every setting but nothing isin't stable
ok time to get hardcore
lets start with the basics try this settings on the vdj options
and try this on the maya console
Set control pannel to 44 hz 16 bit asio, buffersize around 500 (depends what you card has for values_)
if you are using a laptop you could try enabling overclock to boost performance if above doesnt work
i tried everyting you said and i still have the same problems i don't know who is more fed up you or me lol. thats all i can do right now is laugh it off. oh and i have a maya 44 sound card
ok sounds like you should contact the team via ticket on this one
they have acess to tools and info i dont have
contact team
will do thanks for your efforts!
