Forum: Old versions
Topic: VISTA DIRECTX SOUND ERROR ***HOW TO FIX IT!
PROBLEM SOLVED!
Go to control panel then disable everything under sound and video controllers! Then plugin the hercules. worked fine after that! the sound cards were colliding giving me a direct x error!! The internal soundcard wasn't shutting down while plugging in the hercules...so i take it that it was trying to use all 3.
No problems after that! Works awesome!
thanks doug
need help? email me or hit me up via yahoo dougiefreshthedj@yahoo.com
im=dougiefreshthedj for aol and yahoo
I hope this helps some people.
geposted Wed 06 Jun 07 @ 12:29 am
you know what? then how come nobody ever said anything about that? other than i wasnt logged in as admin? i was searching for a problem that didnt even existed cause of you lol
i'm not mad just frustrated...............how come you didn't know that?? a simple tech from comp usa knew it ..........i just told him my problem in under a minute...?? i don't get it...... sigh..............................................i thought you guys were to know your stuff.........
as no one here can actualy see your machine , they have to follow a logical step of things to try
not being loged in as an admin screws the installer which may have lead to the conflict
and usualy solves most peoples issues.
