Hi i have downloaded the pc version demo and i am using in trial version until i get to buy it. But i have got a problem.
I usually use a technique with long samples to mix Progressive/House up to 2hrs of load on every deck.
I am asking why the Max Load setting is set to always but the sample does not load and i do have a lot of ram.
Can i set it from somewhere else??
Thanks and great Soft!!
geposted Wed 06 Jun 07 @ 10:29 am
how much ram?
geposted Wed 06 Jun 07 @ 11:49 am
1GB
geposted Wed 06 Jun 07 @ 12:16 pm
Its a Dell Duel Core T1350 @ 1.86GHz, 1.86GHz
1GB Ram
1GB Ram
geposted Wed 06 Jun 07 @ 12:17 pm
im not convinced that 1 gb is enough
i will investigate.
as the whole files need to be loaded into the ram to play
i will investigate.
geposted Wed 06 Jun 07 @ 2:59 pm
If they are up to 2 hours than it is certainly not enough, try to add another Gb (2Gb total).
geposted Wed 06 Jun 07 @ 3:08 pm
even if the whole file is 200mb?? ... well ok thanks for the help!
geposted Wed 06 Jun 07 @ 3:44 pm
remember other programs are using the ram too windows on it own might use say 700
or in the case of vista 1 gb!!!
geposted Wed 06 Jun 07 @ 7:06 pm
ok thanks for your help!
geposted Fri 08 Jun 07 @ 4:34 pm
No problem, glad we could help!
geposted Sat 09 Jun 07 @ 2:39 pm
