I am a professional VJ/DJ here in Brazil and I am testing the trial version of Virtual DJ. I have a DAC-2 hardware wich I am using with Virtual DJ. I used to play my videos with Power DVD and I ripped all using DVD Decrypter using the default settings and only changed split file by cell id. The problem is that I ripped almost all of my .vob files with ac3 audio, subtitles, etc... I never used stream process to remove the subtitle and the ac3 audio. So these files doesn't load on Virtual DJ. I riped some DVD'S using stream process and all played with sucess. The question is : Does anyone knows a tool to remove the ac3 audio and subtitle and generate another .vob or will I have to rip all my DVD again (almost 2.000 titles) ?
Thanks for any help.
DJ Renato
DJ Renato
geposted Wed 06 Jun 07 @ 8:10 pm
