Forum: Old versions
Topic: need help recording mix
i have an external mixer and i only have 3 jack entrances on my sound card...
2 are for the 2 decks and the other one goes for the mic. . that comes from the recording output of the external mixer.
problem is...
ive tried to record it in several ways and i still havent found the perfect way to do it.
may i get some help please? thank you
i've used several software to record...but the thing is , i can only choose on input to record and the only input i have usable is the mic one... but the sound of it. . .its crappy. . .goes up and down ( the volume ) and if i swap the outputs of the external mixer like. . . putting the recording output to my speakers and the main output to the mic entrance i ear like #$%# and the sound recording is still crappy, i really dont know what to do =|
thankz
geposted Wed 06 Jun 07 @ 8:30 pm
why dont u use the rec option in VDJ itself:)
because it will record master + mic
that way it wont record the changes i make with the external mixer thats why
What do you mean by decks? Please let us know exactly what equipment you are using and what you have laying around. Somebody probably has a solution.
