hi
I cant get my keyboard shortcuts for crossfade (page up /page down ) to work, automix works ok (alt/space),
also what is the keyboard shortcut to swap active decks ? (A/B)
geposted Wed 06 Jun 07 @ 11:23 pm
tab is the between decks key(select between active decks) but u can use the default shortcuts or make your own.
geposted Wed 06 Jun 07 @ 11:31 pm
ok
I have worked out that I need the backspace button to switch beteen active decks A/B can you please tell me how to configure my headphones so I can listen to the cue on the next track to be played (I do have two sound cards )?
Thanks
Thanks
geposted Sun 10 Jun 07 @ 1:53 am
choose
the two soundcard picuture on sound options
and the headphones picture choose
the two cards and press ok
geposted Sun 10 Jun 07 @ 1:34 pm
Ok I have done that
where do I plug the head phones in to listen to the off air tracks ? i can only hear the main track that is playing through the head phone socket
thanks
thanks
geposted Sun 17 Jun 07 @ 8:29 am
I am using Atomixmp3
geposted Sun 17 Jun 07 @ 8:31 am
how can i change languages?
geposted Sat 23 Jun 07 @ 8:09 pm
by reinstalling using a offical installer
hope to see you as a registered user of atomix soon
geposted Sun 24 Jun 07 @ 1:51 am
