alright guys i've figured out the problem when the automix starts to mix then jumps to 3/4 of the mix and starts agian...........do you wanna know wat the problem is? it'll cost you a beer each..
anyway its the safe mode
turn it off overclock is alright then you set the latency to as high as it'll go for sound quality
hows that?
believe me i know me and my lady use virtual dj 3 times a week for the last 2 years and my lady will only use 3.4 cuz the 4.s where unstable.....i've spent the last however long since then trying to get the other versions to work....so i did it.
try it tell me if it works for you
by the way guys this program is to best from start to finish good effort to all of the developement team!!!! you made a very practical and solid program.
hows that?
geposted Thu 07 Jun 07 @ 8:06 am
