Hi there,
Is there anyone who has/had such a problem like me? Pls download the following mp3 and check the tempo.. it is frustrating
http://anubis.org.pl/samplemix.mp3
I am using:
Amd 64 AM2
Win XP SP2
1Gb ram
MSI motherboard
and Dj console - this one http://www.techbox.pl/aktualizacja/data/galerie/232.jpg
+ Virtual DJ *trial version*
checked with 2 soundcards (integrated REaltek and SB Audigy2 ZS) with the same results
pls help :)
H.
I am using:
Amd 64 AM2
Win XP SP2
1Gb ram
MSI motherboard
pls help :)
H.
geposted Thu 07 Jun 07 @ 11:12 am
'your link doesnt work, and your problems might be releated to using that "trial version"
geposted Thu 07 Jun 07 @ 6:09 pm
hi there, just dl this sample mix n did a check, well it is at 131 bpm n the tempo is ok even tho not PERFECT ( a bit, i repeat abit off) but that not the problem as u can nudge it to follow the next song tempo or u could manually try to tap it . What i suspect that the reason y the tempo abit off, cos i guess it been edited b4 using other editing software n not properly crop:). BUT overall its ok and usable. Thats all.
geposted Thu 07 Jun 07 @ 7:56 pm
