Is there a mapper for Numark total control coming soon?
geposted Thu 07 Jun 07 @ 9:58 pm
mappers are created by forum users , who own the console and know how to program:)
and would like to share their skils with other users
so is its dependant on having both of the above
some one who can code and owns it :)
geposted Fri 08 Jun 07 @ 12:46 am
I have programming experience and i have an NTC
Never programmed in XML but had a quick look and it looks easy to pick up.
I'm guessing i would need a software utility that intercepts the midi signals sent from the controller and displays their values on screen, i could then just modify a current mapper for a different device modifying the values to suit the desired actions.
For additional actions, i could first create a keyboard shortcut for the desired action and then check the Shortcut.XML file then use this as a basis to add addtional functions to the NTC mapper.
Or is it more complicated than this?
geposted Wed 20 Jun 07 @ 4:51 pm
@lack1
Why do you want a NTC mapper, you don't need one, it is a plug and play device, and every single button works perfectly with VDJ.
Now, if you want to rederect the action buttons.........then that's another story .
geposted Thu 21 Jun 07 @ 3:56 pm
I think he wants to remap actions (that's what i assumed anyway)
Personally i'd love to add pitch + and - to the controller. I'm using keyboard shortcuts to do this at present.
Musicguate: Have you noticed that the pitch sliders on the NTC seem to require drastic movement before they actually move on VDJ after syncing one deck with another. After the drastic movement they will respond to more subtle movements, but not before.
geposted Thu 21 Jun 07 @ 4:48 pm
YES!!!! Sometime They do not respond.
geposted Thu 21 Jun 07 @ 5:57 pm
If you are using sync to automatically match BPM, this could be a 'safe' pitch feature - This means that if you change the software pitch in VDJ (E.g: Move the sliders with the mouse, use sync or any of the auto mixing features), you must move the physical slider to the correct new position before you can make any adjustments using it.
geposted Thu 21 Jun 07 @ 7:35 pm
Yes Digimixer, they get a bit stuck, but the what I'm doing is not use the sync feature unless it is very necesary, the easy part about it is that the pitch control you have with NTC on manual is a lot acurate than with the mouse, so at the beggining was kind of hard, but once you get used to it is very nice and It feels like you are really making a mix without help.........jejejeje.........but it would be nice if someone can make a fix for this.
What I do for the +and - pitch is without having the scratch feature on, I use the jog whell to sync it manualy and it works very nice, do not turn it to fast as the voice pitch will change a bit.
I haven't tried what JPBOGGIS is saying, thanks man, for the comment, I will try it tonight.
geposted Fri 22 Jun 07 @ 4:01 pm
I think it is an initialization action, I always make it a point to run my pitch sliders all the way up and down when I power on the unit...and tweek all the knobs and dials....just to make sure....
geposted Fri 22 Jun 07 @ 4:16 pm
Tear Em up thanks will try that myself.
Musicguate, didn't mean pitch + and - as a nudge, i mean to permanently adjust the pitch
say from 125bpm to 125.1 bpm (permanently)
Sometimes i have track playing which is 125bpm, then the other deck has a song queued at 127bpm
Rather than reducing the queued track to 125bpm, i like to gradually and slowly increase the bpm of the playing track so that i have it eventually track at say 125.8bpm, that way i'm keeping the queued fairly close to its intended playing speed when mixing it in.
Don't like doing this with the pitch faders as i like to increase in very small increments.
geposted Fri 22 Jun 07 @ 5:39 pm
Well I can hold off on this.........Numark is backlogged and no one has them to sell.
geposted Fri 22 Jun 07 @ 6:52 pm
