hey is this laptop good for vdj audio mixing is it good all round
http://vaio.sony.ie/view/ShowProduct.action?product=VGN-N21E%2FW&site=voe_en_IE_cons&pageType=Overview&category=VN+N+Series
geposted Thu 07 Jun 07 @ 10:52 pm
Sony Vaio ROCKS... .
And is for example used by the international House DJ star Dennis Ferrer with VirtualDJ ;)
And that beast you found will work great;) dual core, giga ram.
Not the best video card, but can mix video on a Vista system
geposted Thu 07 Jun 07 @ 11:00 pm
really cool thanks i cant wait to buy it;)
geposted Thu 07 Jun 07 @ 11:05 pm
For Vista and video use you must add another Gb of ram memory.
geposted Thu 07 Jun 07 @ 11:25 pm
True, if you want to use Aero in Vista, you need more ram.
Doesnt cost much to go for 2 giga ram :)
geposted Thu 07 Jun 07 @ 11:29 pm
i wont b doing any video mixing do i still need more ram....why????
geposted Thu 07 Jun 07 @ 11:30 pm
No need if you arent video mixing :)
But if you are, in VISTA ONLY, the Windows system use a lot of ram for the fancy looking Aero effects.
And your laptop has shared memory with the system as graphic card memory.
So what Alf is saying, is that it might not be super fast for video mixing in VDJ, if using Vista:)
but arent doing video mixing ;)
geposted Thu 07 Jun 07 @ 11:31 pm
ok thanks il tell ye how i get on:)
geposted Thu 07 Jun 07 @ 11:37 pm
i personaly turned all that off it wastes so much cpu and ram
i can run a high end game and use less cpu and ram , than areo needs
geposted Fri 08 Jun 07 @ 12:06 am
oh rite
geposted Fri 08 Jun 07 @ 12:14 am
if you don´t want to put in more RAM in the computer u can just buy a usb stick with 1,2,4 or 8Gb size and use Readyboost in vista, then the usb stick will be working as extra RAM to yer machine
geposted Fri 08 Jun 07 @ 9:35 am
Love my Vaio with Vista.
geposted Fri 08 Jun 07 @ 2:36 pm
@ wasabitech .... that's interesting .....i'll check that out
geposted Fri 08 Jun 07 @ 5:20 pm
ait :D also one good thing is that ddr2 so dims has gotten realy cheap, here in sweden 1Gb costs
around 35 euro
around 35 euro
geposted Sat 09 Jun 07 @ 11:45 am
