Can anybody help me figure out this problem, it says it at the beginning when you open virtual dj (Database is Corrupted) and all my songs wont show the bpm, and i have to start all over someone please help?
geposted Fri 08 Jun 07 @ 12:34 am
go to
C:/programfiles/virtualdj
open virtualdjdatabase(yourname).xml
and look at the song tags
ensure they all look like this
<Song FileName="Noir - 16 - Killing.mp3" FileSize="3539072" TagDate="701160623">
<Display TagRead="1" />
<Infos SongLength="7801344" />
<BPM Bpm="17640" Phase="12592" BeatPhase="1" />
<FAME IsScanned="1" Volume="7982" />
<Automix MixType="3" TempoStart="453592" TempoEnd="6662872" CutStart="453632" CutEnd="7209408" FadeStart="38400" FadeEnd="7349760" />
</Song>
a currupted database usualy ocurs when tags arnt closed
</Song>
geposted Fri 08 Jun 07 @ 12:42 am
thank you...... but one more problem, i am trying to mix and when its recording it skips why does it do this?
geposted Fri 08 Jun 07 @ 12:52 am
whats your spec?
geposted Fri 08 Jun 07 @ 1:02 am
What is Spec
geposted Fri 08 Jun 07 @ 1:04 am
computer specification
what processor
how much ram
what processor
how much ram
geposted Fri 08 Jun 07 @ 1:10 am
All i know its windows xp but how do u figure out the Ram?
I think its the bitrate when you go to encode of MP3 (Plugins)?
I put 128Kbs and i think its starting to work i put it to the test and looked at the seconds and it didnt skip at all so i dont know if i made it work or what?
geposted Fri 08 Jun 07 @ 1:17 am
use this to discover your spec
http://www.belarc.com/free_download.html
geposted Fri 08 Jun 07 @ 1:24 am
Windows XP Professional
Intel Pentium III Processor
665 MHz 256 Mb Of ram
geposted Fri 08 Jun 07 @ 1:44 am
thats probably the cause your computer only just meets the requirements
you shoud consider upgrading the ram
and processor
or using the lower bitrate encoding
and processor
geposted Fri 08 Jun 07 @ 2:01 am
Thank You
geposted Fri 08 Jun 07 @ 2:06 am
