got an old hercules mk1 - all i need now is to cue using headphones - whats an easy cheap viable option - i'm new to computers !
cheers!
cheers!
geposted Fri 08 Jun 07 @ 1:05 am
you need a usb 4.1 soundcard with two outputs
can get them for about 15£ or 30$
geposted Fri 08 Jun 07 @ 1:08 am
You should be able to cue through the Hercules. The front headphone jack.
Just make sure you choose the console in the soundcard setup.
Be aware, you won't be able to use an external mixer like normal in this configuration.
geposted Sat 09 Jun 07 @ 7:22 pm
