Forum: Old versions
Topic: Which Soundcard?
Which soundcard is best to use with the mac... any preferences?
geposted Fri 08 Jun 07 @ 12:54 pm
If your wanting to use Timecode...Currently the only card that works is the Virtual Vinyl card.
If you DON'T need timecode you can practically use any USB/Firewire soundcard with 2 stereo outputs with MAC drivers...
Numark DJ i/o is great sound card for 99$... Made to work with this and the Total Controller
Are you talking about the Numark Virtual Vinyl card? Is the card compatible with Virtual DJ? what features doe it have? I want to use timecoded vinyls, will this work? And I also want to have a video ouput.
Then the numark virtual vinyl package is for you,
yes it does work with virtual dj ( infact full virtual dj under the name of numark cue is bundled with it)
you get a good 4 in and 4 out sound card
two coded vinyls and two coded cds
Actually, you get 4 in and 6 out...there is a thrid output to use with the sampler ;)
even sweeter then
djstore.co.uk needs to update their description too :)
skyfxl wrote :
even sweeter then
yeah, and you need to buy a package to sky, just to see how sweet it really is..hehe
well then i start working full time in a month or so i will cant wait :)
Sounds good! I can give me personal guarantee that you won't be disapointed:)
I have found the Giga Port - AG works well. I have used it in my PC for 3 years with no problems and I am now using it in my Mac with great results. Just plug and play in the mac, no extra drivers needed. Drivers are available but I have not needed them. I'm new to the mac world so this might be rare thing? The downside is that it is an output sound card only, no inputs. However, I just use it for DJ sound output.
