vdj is like my wife..had her for awhile now.she gives problems but i would never trade her for the world.my setup is a little different from most of you guys.I have no external setups just the shortcut keys on my hp notebook.the problem is my dual sound card. i can not upgrade to 4 still on 3.tried every tweak possible still sound glitches when i want them least.the upgrade to 4 works perfect with single (internal) sound card.but the sound quality is a little off.my question is this....is there anyway i could use one external sound card with a y splitter and not loose too much sound quality?might be a dump question or whatever but plz help with some advice
geposted Fri 08 Jun 07 @ 8:29 pm
try on v4 to set
on performance options
fastest
untick safe and overclock
and set autolatency this should clean it up
fastest
geposted Fri 08 Jun 07 @ 8:36 pm
