Hi all, i am trying to get the show logo plug in to work but every time i try loading my logo i get an error saying unable to load file.
I reduced the size of the file to 800x600 and saved in multiple formats including JPEG. and PNG.
Any suggestions ?
Any suggestions ?
geposted Sat 09 Jun 07 @ 4:21 am
hmm, try even smaller
800x600 seens pretty big for a logo, bigger than most video files (unless its HD format)
geposted Sat 09 Jun 07 @ 4:23 am
I tried going lower than that and still no luck.
Anyone else get it to work. I searched on the forum but found nothing helpful from previous post.
geposted Tue 12 Jun 07 @ 12:26 am
Try activating the plugin first, then loading the image. Also try using BMP format, as this works better with the "Mask" Feature.
geposted Tue 12 Jun 07 @ 2:01 am
I got it. It turns out i had unchecked hardware accel.
Once i turned it back on all was good.
Thanks to all that helped, u guys r great.
geposted Tue 12 Jun 07 @ 4:26 am
