Hi VDJ Dudes!
I want to buy 2 new TT's for using my TCV's.
I think i don't need a 1210 mk2 for TCV using or? This are my first TT's and i want some which i can use longer than 2 months... .
TT's which i want to use for TCV's dont have to be that High-End Turntables or? My budget is about 400€. In my opinion is that enough for only TCV using!
I hope you can show me some nice offers.
Thx :)
(and sry for my bad english ^^)
Thx :)
geposted Sun 10 Jun 07 @ 3:15 pm
Its not the fact that the tables are fpr TCVs, It is he motors and drive systems. In effect TCVs have all the same qualities of a normal LP, they just use the information differently. I would recomend either the Tehcs or the higher end Numarks. But please do not let the fact that you are going to use TCV cloud your judgement. Shop as if you were going to play regular vinyl.
geposted Sun 10 Jun 07 @ 3:46 pm
Right on. I would personally recomend the Numark TTX series. They are a joy to play on and a bit less expensive than the techs.
geposted Mon 11 Jun 07 @ 1:01 am
And if you don't wanna spend what the TTX costs, and can do without the display, bpm counter etc. the TT500 is a really good choice, sporting the same motor and tone-arm system as the TTX, but with a considerably lower price.
Worth mentioning though, is that the latest version TTX now come equipped with an USB connection(instead of the S/PDIF that used to be there) and you can record your vinyl directly to your PC/MAC without having to connect through a sound card or external mixer. Perfect if you have a lot of vinyl you need to convert to start using VDJ/CUE/VV
geposted Mon 11 Jun 07 @ 2:40 am
