laptop: hp dv9308, 1 gig ram, geforce 6150, yes i know its not recomonded for video but i had to test it for may self. i'm glad i did, it rockin. so far no problems with the video side of it. the music side is even better. i can say i saved myself about $400. now i'm out for that icdx.
geposted Mon 11 Jun 07 @ 2:05 am
good luck with it , hope it works great for ya .....with 1 gig ram , if you keep a "clean machine" you should be fine.......
icdx's ehh ?? that's on my list too ......
geposted Mon 11 Jun 07 @ 2:10 am
it will be upgrade to 2 gig, and will be only for djing. no downloading email or other programs. straight VDJ only!!!!!
geposted Mon 11 Jun 07 @ 2:14 am
You could just partition your hard drive so that you can have one OS installed just for VDJ and the other for everything else.
geposted Mon 11 Jun 07 @ 7:54 am
Just curious, is it a dedicated video card you got? Or integrated in the mother board?
geposted Mon 11 Jun 07 @ 2:21 pm
it is shared ram but vdj requirements are 1 gig of ram. so do the math. laptop will have 2 gigs. the geforce 7600 video card is a 512 dedicated card. this will be a VDJ laptop only very clean. it run so smooth.
geposted Mon 11 Jun 07 @ 4:28 pm
With 2 gigs and a dedicated 512 video card your system should be running smoooooooooooth.
geposted Mon 11 Jun 07 @ 6:12 pm
When using XP the Geforce cards run VDJ Video vary bad.
But with Vista installed your Geforce card should run fine.
I have a back-up dell laptop that works fine for video with 1gb mem and only 64mb video ram.
geposted Tue 12 Jun 07 @ 12:49 am
hallo hab ne frage?
geposted Tue 12 Jun 07 @ 3:03 am
jacksaw wrote :
hallo hab ne frage?
please speak english or use the forum for your langauge
geposted Tue 12 Jun 07 @ 11:32 am
