ok, i updated my drivers for my mk2 console and they update normally. But the problem i have is with the hercules dj console mk2 updater, it asks me to connect or reconnect my console. i do that but, it doesnt recognize it.
geposted Mon 11 Jun 07 @ 6:44 am
ok what os are you using and which drivers?
geposted Mon 11 Jun 07 @ 10:41 am
os? what do you mean?
geposted Mon 11 Jun 07 @ 7:32 pm
vista or xp?
os = operating system
geposted Mon 11 Jun 07 @ 7:57 pm
vista
geposted Mon 11 Jun 07 @ 8:02 pm
ok heres the fix, vista by default makes your acount a limited user which damages the installation
1. uninstall the console driver
2. uninstall the virtual dj software
3. reboot
4. go to control pannel look at user acounts , go to usergroups , and add your acount to the administrator group
5. reboot
6. install the driver
7. Reboot
8 install the software
Horray it works
3. reboot
5. reboot
7. Reboot
Horray it works
geposted Mon 11 Jun 07 @ 10:26 pm
