Forum: Old versions
Topic: M-Audio Ozonic controller integration help
Hope someone can help. I just bought the M-Audio Ozonic keyboard to work with Virtual DJ and Hercules. I use it with a WinXP laptop through a midi to usb cable (don't have firewire on my laptop). Can someone point me in the right direction for integrating all of these (if possible).
Thank you all in advance.
Dr.Feelin
geposted Mon 11 Jun 07 @ 11:31 pm
to use a midi device such as a keyboard you will need to upgrade to virtual dj pro
Thank you, but before I spend the money, will this work? How will I integrate all these components? Should I upgrade everything?
I appreciate the input, right now all I get to do is stare at my keyboard.
