I got it installed and working. What I wanted help with I want to use it on a chat program caulled camfrog and dj in the room but I can't get the setting right so the room can here me dj.
geposted Wed 13 Jun 07 @ 10:21 pm
hum what does camfrog support as inputs?
geposted Wed 13 Jun 07 @ 11:12 pm
also I am not going to use any speakers cause I don't need them. So I plugged in the usb cable bu the other cable I have no idea where to plug that in
and camfrog is setup like this
http://img441.imageshack.us/img441/5179/helpwg4.jpg
geposted Thu 14 Jun 07 @ 2:50 pm
I think you will need to put the "Other cable" from MK2 into the "mike" connection of your PC
geposted Thu 14 Jun 07 @ 4:15 pm
also forgot to ask what will they hear cause the button on the front for changing the sound on the headphones will they hear that too or not ??
geposted Thu 14 Jun 07 @ 4:18 pm
The headphone control on the front is for listening to the cue'd record so only makes a difference to the headphones you are using
geposted Thu 14 Jun 07 @ 4:37 pm
thanks for help with the headphones stuff
geposted Thu 14 Jun 07 @ 4:59 pm
No probs. Post a link when you are on and I can test it out for you.
Did the Jags get good games in todays fixture lists?
We have to go to Gretna on Boxing Day. Rubbish?
geposted Thu 14 Jun 07 @ 5:20 pm
well I got it working on most other chat programs it is just camfrog that is the problem :(
geposted Thu 14 Jun 07 @ 8:19 pm
ok I take that back it now works for none of them
geposted Thu 14 Jun 07 @ 8:57 pm
see the other wire the one with the red and white on it. where do I plug it into on the console
geposted Thu 14 Jun 07 @ 9:34 pm
I have small jack output in 1/2 going to speakers
I have Red/white cable going to input on my PC soundcard
geposted Fri 15 Jun 07 @ 12:44 am
I don't understand where did u put the red/white cable. did u put the red cable into the dj console and the other end into sound card or the other way around. If so where on the console do I stick it thanks
geposted Fri 15 Jun 07 @ 7:36 pm
Sorry if I not been clear I am also new to this.
I have red/white in the MK2 = Output 1 and 2
From there to input on my PC's sound card
geposted Fri 15 Jun 07 @ 9:24 pm
Iinto the mic on the pc. sorry to sound so dumb but the instrctions that come with it are crap
geposted Sat 16 Jun 07 @ 3:41 pm
