Please , I have gig coming up in a week and i cant figure out how to put 2 tccd together.
I have the orginal which works fine off 1 cd turntable I ripped it then burned it. dont know if that was ok to do?
i can hear the timecode off the new cd but i keep gettin a cant find error no signal????
Please help!!!
Please help!!!
geposted Fri 15 Jun 07 @ 3:40 am
are you using mk2?
what cd players?
what cd players?
geposted Fri 15 Jun 07 @ 12:59 pm
Thanks , but I figuered it out. It was my timecode cd. It seems the one I ripped to my pc was'nt working.
I used an old one i had laying around burned at -9db. And it worked fine , so im happy with that...
But, just so know Im using Denon 3500's and Mk2 with an external mixer. But, while I have your attention could you help me with another subject? My system is always glitching, Im running an hp pavilion duo core amd tl -50 1.6ghz , 1gb of ram , and120 gb of hard drive. I have done some minor tweaks seems a little better but, could use more improvement. Also, im running vista and i have all the new drivers updates etc. Also im using asio 4 all ,I heard it could be something with an external sound card. But I dont understand how that would make a difference, if I need one could you tell me so ,I can get one?
geposted Fri 15 Jun 07 @ 10:16 pm
