I know somewhere in this forum read a post about how you can modify the software so everytime you open a music folder will appear sorted by bpm.
Can someone tell me how if can give me the link to the post I'm talking about.
Thanks a lot
Thanks a lot
geposted Fri 15 Jun 07 @ 8:57 pm
You are looking for this:
http://www.virtualdj.com/forums/42288/Plugins/Registry_explanations.html
Look for "Sort order"
This should be sticky or part of a faq ;)
geposted Sat 16 Jun 07 @ 3:04 am
Thanks, but what I'm actually looking for is that I know you can modify VDJ so everytime you open a folder on the browser instead of opening all the song sorted by alphabetical order will be automatiacly sorted by BPM.
geposted Mon 18 Jun 07 @ 3:53 pm
"* AutoSort: automatically sort the data in the specified column of the browser
0 - disabled
1 - sort the first column
2 - sort the second column
3 - sort by bpm
4 - sort by time
5 - sort by commentary"
Did you saw option number 3? It will do exactly what you want :)
0 - disabled
3 - sort by bpm
4 - sort by time
geposted Tue 19 Jun 07 @ 5:47 pm
Thanks DJ-ALF
But, can you be a little bit more specific, how do I get to the Auto sort, is that in VDJ or where ?
geposted Tue 19 Jun 07 @ 7:03 pm
I think he is talking about going to the reg edit in vdj and changing the number to nect to autosort.
geposted Tue 19 Jun 07 @ 7:56 pm
In Windows Go to Start>Run Type regedit, open this key:
HKEY_CURRENT_USERSOFTWAREVirtualDJ
and find this sub key:
AutoSort
change its value to 3
Thats it ;)
AutoSort
Thats it ;)
geposted Wed 20 Jun 07 @ 11:47 am
Thanks a lot for your help.
One less thing to worry about.......jejejejeje
geposted Wed 20 Jun 07 @ 3:49 pm
LOL
Go get em' ;)
Go get em' ;)
geposted Wed 20 Jun 07 @ 4:21 pm
