Forum: Old versions
Topic: i need your opinion
Hello !
i use VDJ 4.2
i want to buy Hercules Dj console MKII and timecode vinyl and a pack of Stanton DJ-LAB 2 and hier is the link :
http://www.sonovente.com/sono/produit.php?id=4697
So will this work with my VDJ ? The mixer is only 2 lines !
please give what you think about this ?! i'm new here !
thanks
Best regards ..
geposted Sat 16 Jun 07 @ 9:10 pm
take a look at vitrual vinal from numark. its not sure if its cue le or pro but if wanting vdj and tcvs thats the way to go
www.numark.com
go to computer djs and look at the one with two records there
Well thank you anyway for ur opinion . But there is no turne table !!! so i must bay numark virtual vinyl and trune tables , it expensive for me ! i'm new Dj .thanx anywayz ;-)
I need more Opinions plz guyz help me ;)...
Well Dj's
What about this pack wich is in this link : http://www.sonovente.com/sono/produit.php?id=4697
and Maya Usb 44 and timecoded ?
But the problem is , when i red the tutorial how to setup VDJ with timecode, i MUST have a mixer of 3 CHANNELS . is that true ?
The Mixer in this pack has only 2 chanels , will it work for me ?
I saw in youtube.com this video and this guy has a mixer of 2 Chanels
http://www.youtube.com/watch?v=E3L1t2Ic-lI
Help me plz thanx in advanced .
i think a 2 channel mixer works fine if you want to play 2 turntables with tcv's. i would recommend better turntables.but the package you chose should work fine with hercules mkII or maya44 usb you only need the pro version of vdj.
Thankx a lot Bro !
but i wanna know one thing . Is the VDJ version 4.2 pro edition? , it'll work fine with TCV's and maya Usb ?to bay it .
Thanx again Djey ;)
the 4.2 version is a trial or cracked version.. you will need to buy the 4.3 pro version in order to play timecode vinyls without any limitations and to download skins, plugins etc...
greetz mars
