Hi there,
I recently installed a fresh copy of windows vista. I had moved all my music onto an external harddrive, and kept the VDJ database xmls.
How do I go about restoring my database into a new copy of Virtual DJ?
geposted Mon 18 Jun 07 @ 12:27 pm
Hmm i figured out the problem, the pathnames in the xml is for XP (ie. C:\Documents & Settings\<User name>\File
in Vista there is no Documents & Settings folder, so the path cannot be read. How would I go about changing this?
geposted Mon 18 Jun 07 @ 12:59 pm
Ok, ignore the above post - I realise the path names are only needed for favourite folders..
Where is the database XML kept in Vista? I deleted all the database files out of the main directory but it still keeps tab of which files have been analysed.
Which database file am I supposed to replace with the original database file I saved?
geposted Mon 18 Jun 07 @ 1:28 pm
Read this thread - specifically my post -- 5th one down --
http://www.virtualdj.com/forums/65871/PC_Version_Technical_Support/Vdj_Database.html?highlight=vista%20database
geposted Tue 19 Jun 07 @ 3:08 am
