To Preface:
My problem system is :
Intel Duo Core2 2 2.4ghz
2 gig ram
XP Pro v. 5.1.2600 Service Pack 2 build 2600
Nvidia GeForce 7900 Gs video card
My Problem just started today whenever I clicked on Virtual DJ from my desktop. A message comes up : "The Internal Database Is Corrupted"
Then I click on ok and proceed to use Virtual Dj without any issues. Anyone have any info they can share with me to correct this issue?
Many Thanks in Advance!
Kev
2 gig ram
Kev
geposted Tue 19 Jun 07 @ 2:05 am
Download this utility - http://www.virtualdj.com/addons/download.html?addon_id=2560
Save the zip in the c:\\Program Files\\VirtualDJ folder.
Extract the files to same location.
READ the readme_runVDJ.txt for using the utility/program.
Good Luck - and post back if you have further problems.
cstoll
cstoll
geposted Tue 19 Jun 07 @ 3:05 am
Ok, so I downloaded the file - thanks for that, by the way CSTOLL ; )
Ran it as instructed in the readme file and now I get this:
AutoIT Error:
Line 0 (File "C:\Program Files\VirtualDJ\RunVDJ\RunVDJ.exe )
RunWait ("VirtualDJ.exe", $VDJHome )
Error: Unable To Execute The External Program
The System Cannot Find The Specified File
So I'm going to remove the file and try loading and running it again in the meantime.
AutoIT Error:
geposted Tue 19 Jun 07 @ 6:57 pm
What OS are you running?
And did you install VirtualDJ in the Default Directory?
When you extracted the files did they go into a directory called - RunVDJ? If so, move the files back to the c:\\Program Files\\VirtualDJ folder. And follow the instructions again.
cstoll
cstoll
geposted Tue 19 Jun 07 @ 7:16 pm
