I got a corrupt data base error, now my cue points arent there or my bpm's. Also, when using the maya44 soundcard it only works one one side, and on the other the record on vdj is spinning but no music is coming out. When I take it off of TCV that side works fine. I dont use this pc for any type of internet surfing or install any other programs. I'm going to reinstall XP again and start fresh, reinstall the maya44 drivers and hopefully that fixes my situation. Any idea what happened?
geposted Tue 19 Jun 07 @ 2:22 am
For your corrupt database problem --
Download this utility - http://www.virtualdj.com/addons/download.html?addon_id=2560
Save the zip in the c:\Program Files\VirtualDJ folder.
Extract the files to same location.
READ the readme_runVDJ.txt for using the utility/program.
As for your Maya issues -- Use the 2.5.5 drivers. But it should work fine if you choose Maya as the sound card or the ASIO. Make sure you always re-plug the Maya into the same USB port everytime (if you are using a laptop)
Good Luck - and post back if you have further problems.
cstoll
cstoll
geposted Tue 19 Jun 07 @ 3:39 am
i have dj mixstation 3 with licence i get a internal database error what do I do
geposted Tue 19 Jun 07 @ 2:41 pm
Please register your software here - http://www.virtualdj.com/fusers/modifuser.html
Then come back to this thread and send me a PM by clicking on the envelope that you will see under my name (at the left) once you register. If you are unable to register please visit the DJMixstation site and read the last tip on this website on how you can resolve your registration problem. [ http://support.empireinteractive.com/default.aspx?MID=60568495217F&PID=C5902015-DB47-4E8D-89E8-1BEF8D47E674 ]
cstoll
geposted Tue 19 Jun 07 @ 11:54 pm
