Forum: Old versions
Topic: Question with database
Hello, I've got a quick question that I need assistance with.
In my backup setup which also has VDJ loaded, the database deletes itself every time I close the program. Next time I open it up, I have to scan my HD again. Why is it doing this?
Thanks in advance...
geposted Wed 20 Jun 07 @ 5:19 pm
That's very strange, never seen VDJ does this. What version do you use? Write your PC specs.
It's version 4.2 still.
Toshiba (Satellite P25-S477) laptop with 2.40 GHz Pentium 4, 1GB RAM, 120 GB hard drive
Are you using XP or Vista on that machine?
Nope, it's got XP
I suggest only fresh install of XP and VDJ 4.3 and try it then. It is weird for sure.
It has happened to me at random times, a nother bug needs to be fixed. Happens on multiple laptops. No longer a system problem. A VDJ problem.
pardon moi but how can it be a VDJ problem when its not happening to everyone running VDJ? Please explain.
Please, try reinstall of your OS, might solve the problem.
