Forum: Old versions
Topic: software update causing fader noise problems
Having updated VDJ software to latest version and updating Dj Console Mk2 to latest software but now evry fader movement causes noise to be output whether using a mouse directly on the software or using the DJ Console. Any ideas?
geposted Wed 20 Jun 07 @ 10:55 pm
I had that troubles a few days ago.
Here is what you gonna do.
Reverse old 2006 drivers for MK2 and firmware too. 2007 drivers works good on Vista only, but I think they are buggy all the way.
Update your Direct X to the latest June one:
http://www.softwarepatch.com/windows/directx.html
and in settings of VDJ Select Latency on 512/11ms and turn on Overclock and disable Safemode.
Hope this helps.
